layer 2 streched with fabric path and layer 3 is connected via hsrp active/active
mod13
Hello
we have two sites (primary / secondary) connected via dark fiber(redundant physical links) and layer  2 stretched  via fabric path.  Also we have one router at each site(MPLS) connected via hsrp(Active/Active).  Idea is to failover from DR standpoint automatically.  question if we ever loose layer 2 between two sites.  how  will the traffic flow from other mpls sites since the layer 2 stretched?
balaji.bandi
As long  as you resilient connection in port-channel with different routes you should be good. ( you need to design best practice considering some failure scenarious).
If both link fails it will be split brain situation.
BB
BB
exactly that the question to avoid split brain situation.  is there any best  practice document?
