Layer 2 Traffic
dannymcca
hi,
PLEASE HELP, I am getting desperate to resolve this. Thanks
I have 2 887va routers which are both connected to an ADSL line and I have set them up to pass layer 2 traffic via L2TP.
I am injecting layer 2 traffic into one of the routers using Colasoft and the PC at the other end os monitoring the traffic with wireshark.
My problem is nothing is coming accross the tunnel, in fact I believe thast the traffic is not even getting to the tunnel as the ports are not set up crrectly.
I have configured the F1 with
# Switchport Access Vlan 200
# no shutdoen
I then connect the ethernet cable to port F1 from the PC and with Debug enabled for L2TP All only the hello traffic is shown.
Please can someone help as I think I am missing something simple.
Thanks.
Building configuration...
Current configuration : 3973 bytes
! Last configuration change at 13:03:15 UTC Thu May 2 2013
! NVRAM config last updated at 13:04:17 UTC Thu May 2 2013
version 15.1
no service pad
hostname XXX
boot-start-marker
boot-end-marker
enable secret 4 pozkvcqXiM/f4AVrqz8PjSI9KxXYqhSXdmI.1yi0uD2
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
l2tp-class l2tpclass2
authentication
password xxx
l2tp-class l
vpdn enable
vpdn-group vpdngroup1
accept-dialin
  protocol l2tp
  virtual-template 1
terminate-from hostname xxxxx
license udi pid CISCO887VA-K9 sn FCZ1706908Q
controller VDSL 0
pseudowire-class pwclass2
encapsulation l2tpv3
sequencing both
ip local interface Dialer0
ip pmtu
ip tos reflect
ip ttl 100
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key xxxx address xxx.xxx.xxx.xxx
crypto isakmp keepalive 30 5
crypto ipsec transform-set XXX esp-3des esp-md5-hmac
crypto map Cmap 10 ipsec-isakmp
set peer xxx.xxx.xxx.xxx
set transform-set XXX
match address 101
bridge irb
interface Loopback1
no ip address
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
no ip address
ip nat outside
ip virtual-reassembly in
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
switchport access vlan 2
no ip address
interface FastEthernet1
switchport access vlan 200
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Virtual-Template1
ip unnumbered Loopback1
ppp authentication chap
ppp chap hostname xxxxx
interface Virtual-PPP2
pseudowire xxx.xxx.xxx.xxx 10 pw-class pwclass2
interface Vlan1
no ip address
ip nat inside
shutdown
interface Vlan2
no ip address
bridge-group 1
bridge-group 1 input-address-list 700
bridge-group 1 output-address-list 700
interface Vlan200
no ip address
interface Dialer0
ip address xxx.xxx.xxx.xxx 255.255.255.0
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap password 0 xxxx
ppp ipcp route default
ppp ipcp address accept
no cdp enable
crypto map Cmap
interface Dialer1
no ip address
interface Dialer9
no ip address
shutdown
interface BVI1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 78.105.250.120 255.255.255.255 Dialer0
ip route 192.168.1.0 255.255.255.0 Virtual-PPP2
access-list 50 deny   any log
access-list 100 deny   ip 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 101 permit tcp 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 101 permit udp 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 101 permit icmp 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 101 deny   ip any any
access-list 101 deny   tcp any any
access-list 101 deny   udp any any
access-list 101 deny   icmp any any
access-list 111 deny   tcp any any eq telnet
access-list 111 permit ip any any
access-list 700 permit 0000.0000.0000   ffff.ffff.ffff
dialer-list 1 protocol ip permit
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
access-class 50 in
exec-timeout 0 0
no login
transport input none
transport output none
end
0 Replies 0
