Bookmark
Subscribe
481
layer 3 port bandwidth usage
yuhuiyao
All,
How can I see a layer 3 port bandwidth usage? I have tried but it is not working.
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
L3 in Switched: ucast: 54217685 pkt, 15613598253 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 49891888 pkt, 12027617095 bytes - mcast: 0 pkt, 0 bytes
    54537044 packets input, 16667165219 bytes, 0 no buffer
    Received 279044 broadcasts (74600 IP multicasts)
    50031279 packets output, 13048119837 bytes, 0 underruns
    44 output errors, 60 collisions, 0 interface resets
    0 babbles, 44 late collision, 0 deferred
    0 lost carrier, 0 no carrier
Giuseppe Larosa
Hello Yuhui,
what device is this? A multilayer switch I suppose it may be a cosmetic bug of your IOS image
Hope to help
Giuseppe
Hi Giuseppe,
It is a cisco WS-C4948 (MPC8245) processor (revision 0) with 262144K bytes of memory running on cat4500-entservices-mz.122-46.SG.bin"
I had the same issue with 4507R-E running on cat4500e-entservices-mz.122-46.SG.bin
Thanks.
