Layer 3 switch routing between vlans [Packet tracer][noob]
mblackshore
Hello folks.
I'm trying to allow end devices to communicate between vlans.
I I'm using a Multilayer Switch 3560 24 port. And 4 computers. 2 per vlan.
NAME VLAN IP
PC10_1 10 10.100.10.50 /24
PC10_2 10 10.100.10.51 /24
PC20_1 20 10.100.20.50 /24
PC20_2 20 10.100.20.51 /24
GW: 10.100.X.1
I have created a Virtual Switch INTERFACE, one for each VLAN.
interface Vlan10 - ip address 10.100.10.1 /24
interface Vlan20 ip address 10.100.20.1 /24
Devices can ping eachother and the virtual gateways, but not between vlan.
I assume there is a encapsulation dot1Q needed.
Which interfaces should have this?
Download Running config
2 Accepted Solutions
Hello.
Could you please post the 3560
show run?
Communication with the GW is possible, so maybe the
ip routing
command is just missing.
@cja56910tf
I linked it at the bottom.
But I figured out what was missing.
I needed to type in the follwing in global config mode
ip routing
6 Replies 6
Hello.
show run?
ip routing
@cja56910tf
ip routing
BTW, some Cisco L3 switches have IP routing disabled by default, others Cisco L3 switches have it enabled by default.
balaji.bandi
ip routing
- missing here ?
still not working -
 show vlan, show ip routing
Also check end device have any FW ?
BB
M02@rt37
Hello @mblackshore,
No need of dot1Q here.
Active routing between VLAN with
ip routing
command in switch configuration mode.
Best regards
Blue_Bird
Check for
ip routing
command....in Global configuration mode....
MLS(config)# ip routing
You no need to give
encapsulation dot1q vlanX
  command.....This command is required when we are doing
 inter-vlan routing
by using Router....on router each sub-interface you will be needed give that command... not for multilayer switch with SVI.
I hope the above information is useful...
