LDP Discovery targeted-hello ACL
Sunil_06
hi Team,
i have configured an ACL to reject the targeted Hello from LDP neighbor, but despite of applying ACL, why LDP session TLDP session is showing up.
RP/0/RSP0/CPU0:R1#show access-lists UDP
Tue Jul 30 16:28:26.728 IST
ipv4 access-list UDP
 54 deny ipv4 host 2.2.2.2 any (95242 matches)
 56 deny ipv4 host 3.3.3.3 any (95246 matches)
 100 permit ipv4 any any (364286203 matches)
RP/0/RSP0/CPU0:R1#
RP/0/RSP0/CPU0:R1#show  run formal mpls ldp | include UDP
Tue Jul 30 16:29:06.012 IST
mpls ldp address-family ipv4 discovery targeted-hello accept from UDP
RP/0/RSP0/CPU0:R1#
RP/0/RSP0/CPU0:R1#show mpls ldp discovery 2.2.2.2
Mon Jul 29 14:26:29.906 IST
Local LDP Identifier: 1.1.1.1:0
Discovery Sources:
  Interfaces:
    Bundle-Ether11.100 : xmit/recv
      VRF: 'default' (0x60000000)
      LDP Id: 2.2.2.2:0, Transport address: 2.2.2.2
          Hold time: 15 sec (local:15 sec, peer:15 sec)
          Established: Jul 10 01:17:17.489 (2w5d ago)
    TenGigE0/4/1/7 : xmit/recv
          Established: Sep 19 03:17:05.555 (44w6d ago)
  Targeted Hellos:
    1.1.1.1 -> 2.2.2.2 (active), xmit/recv
      LDP Id: 2.2.2.2:0
          Hold time: 45 sec (local:90 sec, peer:45 sec)
          Established: Apr 13 02:00:05.688 (15w2d ago)
RP/0/RSP0/CPU0:R1#
RP/0/RSP0/CPU0:R1#show  mpls ldp neighbor   2.2.2.2
Tue Jul 30 16:37:57.975 IST
Peer LDP Identifier: 2.2.2.2:0
  TCP connection: 2.2.2.2:646 - 1.1.1.1:22156
  Graceful Restart: No
  Session Holdtime: 30 sec
  State: Oper; Msgs sent/rcvd: 11156540/16079469; Downstream-Unsolicited
  Up time: 45w0d
  LDP Discovery Sources:
    IPv4: (3)
      TenGigE0/4/1/7
      Targeted Hello (1.1.1.1 -> 2.2.2.2, active)
      Bundle-Ether11.100
    IPv6: (0)
  Addresses bound to this peer:
RP/0/RSP0/CPU0:R1#
BR:
Sunil Kumar
10 Replies 10
First target ldp use tcp not udp
Second check direction of ACL with LO IP ypu use in acl
MHM
Hi ,
Thanks for your reply, its just ACL Name "UDP" , i'm not specifying any L4 Protocol TCP/UDP in ACL .
ACL is applied in incoming direction.
Source >>>> Neighbors' Transport address /Targeted Hello source address
Destination >> Any
Targeted Hello also use UDP for LDP hello packets.
BR:
Sunil Kumar
Apply to LO you use as MPLS router-ID 1.1.1.1?
MHM
Hi MHM ,
can you please confirm what is the behavior of below command when applied to LDP and why TLDP is showing up.
mpls ldp address-family ipv4 discovery targeted-hello accept from xxxxxx
BR://
Sunil Kumar
MHM
this for you to explain some point here
in R3 I use LO 3.3.3.3 as LDP router-id
I use ACL under the LO 3.3.3.3 to prevent target ldp between R2 (LO 2.2.2.2) and R3 and it not effect
why ?
to prevent traffic to LO not only LDP you need to use CoPP or use ACL in interface LO use as egress
and that what I do
I apply same ACL to the interface f1/1 and it work
you need to check
xmit/recv <<- if you dont see recv or xmit  then there is ACL drop the target  hello
for command you share
mpls ldp address-family ipv4 discovery targeted-hello accept from xxxxxx <<-
I dont find some detail about it I will make double check and inform you
BUT
this command if available in your router is more better than use ACL under egress or LO interface
The default behavior of an LSR is to ignore requests from other LSRs that send targeted Hello messages. You can configure an LSR to respond to requests for targeted Hello messages by issuing the mpls ldp discovery targeted-hello accept command.
MHM
Hello @Sunil_06 ,
I would expect the command to use a standard ACL and not an extended ACL if all you need to define is the denied and allowed LDP peers LDP router-IDs  .
I would suggest you to try to use a standard ACL instead of your named extended ACL.
Hope to help
Giuseppe
Hi ,
as we can see in the output, counters are increasing it means LDP Hello's are hitting on ACL .
but not sure why it's not denying it.
 54 deny ipv4 host 2.2.2.2 any (95290 matches)
 56 deny ipv4 host 3.3.3.3 any (95395 matches)
RP/0/RSP0/CPU0:R1#
BR://
Sunil
Add deny tcp port 646 to see if target drop or ACL hit for other traffic
And did ypu use target discovery command??
MHM
