Learning Our Routes back on BGP
netbeginner
Level 2
Level 2
Hi All,
We have BGP peering configured with remote end. Observed strange behaviour.
We are learning our routes back to us which we are only advertising to remote end. This is creating a communication issue. Can anyone suggest what happened wrong.
Hello
@netbeginner wrote:
Hi All,
This should not occur due to as-path loop prevention, are you performing any aggregation?
sh run | sec router
Kind Regards
Paul
In addition to the bgp section of the config it would be helpful to have several other things:
- a diagram showing the topology of the network.
- the output of show ip bgp neighbor
- the output of show ip bgp sum
Rick
can we see the config for both Peers
