05-26-2012 10:03 PM - edited 03-04-2019 04:29 PM
Hi All..
We are about to install new cisco 2900 router very shortly. I would like to know following since I have not experience about Cisco 2900 router.
We purchaed the followings from vendor
S29Uk9-15102T
SL-29-DATA-K9
SL-29-SEC-K9
It seems like SL-29-* is the license for Cisco 2900 to activate data and security feature.
However, I would like to know How to activate these licenses on router.
Please let me know the process of activation.
Thanks you.
05-26-2012 11:22 PM
You are right, those are security and SNA switching licencies for ISR G2. See any of the following guides for step-by-step instructions to activate the licencies:
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1115914
Kind Regards,
Ivan
**Please grade this post if you find it useful.
05-26-2016 02:44 PM
Install the License with command
#License install (license file location)
If your technology-package are disabled then enable with following command
(config)#license boot module c2900 technology-package <package name>
Write your configuration and reload command
Verify your license with
#Show Version
Deepak Kumar
Spooster IT Solution.
