08-31-2009 11:19 AM - edited 03-04-2019 05:54 AM
All,
We're configuring new routers and noticed that the IPBase version that we're running doesn't support NTP. We need the K9 version of IPBase. Can we "legally" download it since it's in the same family?
John
Solved! Go to Solution.
08-31-2009 12:44 PM
I don't know. These are 2811's that we just received. They support BGP, so I can't see why they wouldn't support NTP as far as memory requirements. =)
I may have to go up a feature set, but the only thing that I had noticed was that k9 was listed after all of the images that I had looked at.
Thanks Rick,
John
08-31-2009 06:26 PM
John,
Maybe it's the IOS version. I have used the 2800 and was able to configure NTP running IP Base.
If not, try SNTP.
