08-07-2016 06:03 PM - edited 03-05-2019 04:27 AM
Hello all.
I bought license (PAK) and registered PAK through cisco.com/go/license
I registered UID to CISCO2921 ,,,, but,,, its UDI name is CISCO2921/K9
Ha....
How can I deal with it?
Should I buy another one again?
Could you give me device?
Thanks...\
Regars,
Solved! Go to Solution.
08-07-2016 06:37 PM
Yes, this will also work.
08-07-2016 06:09 PM
No big issue. Send an email to license@cisco.com. Give them the details of the OLD PAK and the UDI, Serial Number and your CCO login.
Should be sorted in an hour.
08-07-2016 06:25 PM
Leo!
I found it(below captured picture) and registered again!
Afterwards I got another license !!
Is it possible method?!
08-07-2016 06:37 PM
