License ipbase - OSPF Limitation
Hello guys,
I have a doubt about license ipbase in the Catalyst 4500. There is some limitation about the process OSFP in this IOS referent a quantity of SVI or network that can configure/advertisement in this license?
For example: In this process OSFP only support just 15 SVI or network in this license ipbase.
I not found any information about this in cisco.com.
Pedro
Information about this switch:
WS-C4510R+E
License Information for 'WS-X45-SUP7-E'
License Level: ipbase   Type: Permanent
Next reboot license Level: ipbase
cat4500e-universal.SPA.03.05.03.E.152-1.E3.bin
Mark Malone
Hey your only supposed to be able to learn 200 routes in ospf in ip base and also only have max 255 vlans , not sure about SVIs have not seen a limit on that before, limit in instance as well
Saying that you will see people in this forum have been able to get more on certain IOS versions/platforms than 200 routes learned but there is definitly limits on those licenses
"OSPF for Routed Access: Starting from Cisco IOS Release 12.2(55)SE, the IP Base image supports a new feature called OSPF for Routed Access. OSPF for Routed Access is designed specifically to enable you to extend Layer 3 routing capabilities to the wiring closet. It supports only one OSPFv2 and one OSPFv3 instance, with a maximum number of 200 dynamically learned routes."
Mark Malone
Thanks Mark for your anwser.
