License status on Cisco ISR router
Herman2018
Level 3
Level 3
Hi, we have cisco 4431 router, but not sure need to purchase security license or not as we want to setup ipsec vpn on this router.
Below is the output of the command "show license all". Is it indicating the security license is active and no need to buy any license ?
anyone please advise, thanks in advance!
StoreIndex: 2 Feature: securityk9 Version: 1.0
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Count: Non-Counted
License Priority: None
2 Accepted Solutions
DanielP211
Hello!
Please specify what exacly are you trying to achive. But seck9 will probably be enough.
BR
****Kindly rate all useful posts*****
balaji.bandi
Setting VPN is seck9 License is good enough for - which you already did evaluation right to use. - by default only get 500 Mbps aggregated throughput.
For Permanent you need to buy a License to to retain the License.
if you looking more throughput you need to buy throughput License.
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
Note : IOS XE 16.9.X onwards smart License so you need to use smart License to active the License.
BB
5 Replies 5
Mark Elsen
      - Should  be sufficient ( securityk9), as per https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
         Use the command Router(config)#license accept end user agreement
         too.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks @Mark Elsen for your advice. the existing license is evaluation license, right? for permanent use, we still need to buy a securek9 license, right ?
DanielP211
Hello!
BR
balaji.bandi
BB
Thanks @balaji.bandi for your advice! we need to buy permanent license securek9 . Can you please advise the part number of this license? Thanks in advance.
