internet 3945
Mlex1
Hello, i have Cisco router 3945, working well, when i reboot or after electricity goes down internet doesn't working, i should go to router do shutdown and no shutdown after internet will working.
why does this happen thanks in advance
Wish all the best
Mlex1
we solved this problem, i don't know how i talked to ISP a few times and we came to solution and on my side we will changed sfp. Sfp worked was SC bu we will changed to LC, and also ISP also changed some configs after this problem solved. ISP didn't khow how solved this issue soled me also.
i will close the issue
Wish all the best
17 Replies 17
Hello @Mlex1 ,
can you provide some more details regarding the router itself? Can you share the config and the show version?
Regards, LG
*** Please Rate All Helpful Responses ***
Mlex1
flash0:c3900e-universalk9-mz.SPA.157-3.M8.bin
can't share secret i can share part of config
Wish all the best
Don't need passwords to troubleshoot the problem.
Regards, LG
M02@rt37
Hello @Mlex1
As concerned this specific interface facing "internet", is it a manual or dhcp ip address ?
Best regards
manual
Wish all the best
Ok @Mlex1
The router's routing table or ARP cache might not be getting populated correctly after a reboot. Manually restarting the interfaces may trigger the process of updating these tables.
Best regards
i will emulate this moment next week, thanks for support
Wish all the best
here i didn't see any changes with arp table but my default route disappear, also i see errors on port where cable from provider connect to my switch.
R1#show interfaces gigabitEthernet 1/1/1 | S runts
9 runts, 0 giants, 0 throttles
Wish all the best
JordanHall
It sounds like you might be experiencing an issue with the Cisco router not automatically restoring internet connectivity after a reboot or power outage. This could be due to various reasons, and here are a few common possibilities:
  1. Interfaces not coming up: After a reboot or power outage, the interfaces on the router may not be coming up automatically. You can check the status of the interfaces by using the show ip interface brief command. Make sure that the relevant interfaces are in the "up" state.
  2. Configuration not saved: If the router is not saving its configuration, any changes made during the session may be lost after a reboot. Ensure that you are saving the configuration using the write memory or copy running-config startup-config command.
  3. IP addressing issues: There could be issues with obtaining IP addresses for the interfaces, especially if they rely on DHCP. Make sure that DHCP is configured correctly or check the static IP settings if applicable.
  4. Routing issues: After a reboot, the routing table might not be repopulated correctly. Verify that the routing information is accurate using the show ip route command.
  5. Software or firmware issues: Ensure that your router is running the latest stable software or firmware version. Bugs in the operating system might be causing the issue, and updating to the latest version could resolve it.
ConfiguratioRouting issues:
all good
mansion above my default route disappear
Wish all the best
Mlex1
i don't know how to solve this problem if i know i will share menеioned here, currently i solve this problem via shutdown and no shutdown
i will close the ticket thanks in advance
Wish all the best
You may close the ticket if you want. Or if you want to go a bit further with it I would suggest that after the next reboot, before you shut/no shut perform these commands and post the output
show ip route
show arp
show interface
Rick
Hello Richard
with due all respect, i done all steps i only see one differents my default router disappear, after shut and no shut on port internet working internet.
Currently i'm waiting for ISP
1 They should change SFP modul
2 Connect our internet from another side
result i will share thanks in advance
Wish all the best
peytonjosie3
It sounds like your Cisco router 3945 may be experiencing an issue where the internet connection fails to initialize properly after a reboot or power outage. This could be due to a configuration problem, interface flapping, routing or NAT issues, or even hardware malfunctions. By performing a shutdown and then a no shutdown on the affected interface, you're essentially resetting the connection and allowing it to reestablish properly. To address this issue, you should check for misconfigurations in the router's configuration file, verify the physical connection, review router logs for errors, test internet connectivity using diagnostic commands, and consider contacting your ISP for assistance. If the problem persists, further troubleshooting or consultation with Cisco technical support may be necessary to resolve the issue and ensure reliable internet connectivity.
