Licensing CSR 1000v
a-kamal
Can someone confirm the subscriptions for CSR 1000v are for each instance of CSR or per vNIC?
I have a requirement for 2x CSR 1000v, each having 3x vNICs. Would I go for 2x L-CSR-10M-IPB-1Y= OR 6x L-CSR-10M-IPB-1Y=?
Thank You.
Naveed Khalid
It is per instance, and total throughput. You will go for 2x.
Number of NIC depends on the hypervisor you are using, like ESXi supports up to 10 NICs.
Naveed Khalid
That's Perfect. Thank you.
