Lightstream 1010 - cannot create VPs
dfreir
Community Member
I have recently added a 622MB ATM card to a LS1010 with the intention of moving circuits from an existing 155MB card to the new ATM node.
When the ATM network moved the circuits to the new node, the LS1010 did not recognise the circuits when built as VPs, but did recognise the circuits when built as Vcc.
This was not critical, and I allowed circuits to be built as Vcc.
However, the next circuit to be moved is a remote access solution using ADSL requiring user access to be built as a Vcc circuit within a VP.
LS1010 sees circuit built as a VP as up/down.
Has anyone seen this issue?
Regards.
Derek
smahbub
Level 11
Level 11
When using autoselect, let the activation character default to Return, and exec-character-bits default to 7. If you change these defaults, the application does not recognize the activation request. For more information refer to following url:
http://www.cisco.com/en/US/products/hw/switches/ps1893/products_configuration_guide_chapter09186a00800f0e5a.html
