CWM SNMP Agent: Setting preferred route for a PVC
jbocanegra
Has anyone got to the nuts and bolts of setting svConnPrefRouteDesc ? That is the equivalent of the 'cnfpref' on the CLI.
JM
a-vazquez
Level 6
Level 6
To create a preferred route, use the following procedure:
Step 1 Select a preferred route ID that has not been used for previous preferred routes.
Step 2 Identify the source node and intermediate network elements (NEs) (node name and outgoing trunk port) for the preferred route.
Step 3 Send an SNMP SET on the following objects of the cwmPrefRouteCnfTable:
cwmPrefRouteSrcNode = Source NodeName
cwmPrefRouteShelf =
cwmPrefRouteId = RouteId
cwmPrefRouteRowStatus = CreateAndGo
cwmPrefRouteNECount =
The cwmPrefRouteCnfTable contains one row per preferred route.
cwmPrefRouteNESrcNode =
cwmPreRouteNwElemSrcShelf =
cwmPrefRouteNEId =
cwmPrefRouteNEPos =
cwmPrefRouteNENode =
cwmPrefRouteNEBay =
cwmPrefRouteNESlot =
cwmPrefRouteNELine =
cwmPrefRouteNEPort =
cwmPrefRouteNERowStatus = CreateAndGo
cwmPrefRouteNELast = <1 if the NE is not the last one> <2 if the NE is the last one>
