limit advertising prefixes in bgp on ios xe
wojsal
hello everyone.
My knowledge of bgp is not very great. I started administering some infrastructure and I don't know it completely yet.
I don't have much knowledge about Cisco routers, I used Juniper.
Namely.
I have two cisco 8300 edge routers running cisco ios xe 17.3.
I have bgp sessions with two ISPs on both routers, the session to ISP 3 is disabled because the ISP1 and ISP2 operators offer ddos protection, and the condition was to disable ISP3 so that an unwanted attack would not come through this operator - this is not important at the moment.
all traffic enters us through ISP1, and also goes out through ISP1 to the Internet. I have Fortigate as a firewall, it receives two default gateways from router r1 and r2. I weakened the traffic to r2 so that traffic entering through r1 would also go out through r1. there was a situation where traffic entered through r1 and went out through r2 - I wanted to avoid asymmetric routing.
incoming traffic goes isp1->r1->fortigate, outgoing traffic goes fortigate->r1-ISP1, R2 is basically a slave together with ISP2.
but this is not important either - I want to explain the scheme to you.
I mean advertising my prefixes, currently my entire /23 subnet is advertising. and I wouldn't like to advertise some of my prefixes to the ISP. but I can't achieve it.
I have route-map BGP-PEER-EXPORT
neighbor 77.10.10.11 route-map BGP-PEER-EXPORT out
but it seems to me that it does not filter my prefixes when I check:
1_8300# show ip bgp neighbors 77.10.10.11 advertised-routes
BGP table version is 86384481, local router ID is 90.10.6.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
t secondary path, L long-lived-stale,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 90.10.6.0/23 0.0.0.0 0 32768 and
and my route map looks like this:
R1_8300#show route-map BGP-PEER-EXPORT
route-map BGP-PEER-EXPORT, permit, sequence 10
Match clauses:
ip address (access-lists): BGP-PEER-EXPORT
Set clauses:
Policy routing matches: 0 packets, 0 bytes
community no-export
R1_8300#show ip access-lists BGP-PEER-EXPORT
Standard IP access list BGP-PEER-EXPORT
5 deny 90.10.6.2
10 permit 90.10.6.0, wildcard bits 0.0.1.255 (9 matches)
20 permit 90.10.6.0, wildcard bits 0.0.0.255
30 permit 90.10.7.0, wildcard bits 0.0.0.255
40 deny any (73173543 matches)
in the address family configuration I have the following configuration:
address-family ipv4
network 90.10.6.0 mask 255.255.254.0
aggregate-address 90.10.6.0 255.255.254.0 summary-only
and I don't know if it conflicts with my route map?
I see that I can add route-map to network:
network 90.10.6.0 mask 255.255.254.0 BGP-PEER-EXPORT
like this, but I don't know how it will work? Will I stop advertising the example prefix 90.10.6.2?
I would like to know how to filter what I advertise to my neighbors?
my configs :
r2
router bgp 65000
 bgp router-id 90.10.6.2
 bgp log-neighbor-changes
 neighbor 77.10.10.10 remote-as 60000
 neighbor 77.10.10.10 description ***PEER-1***
 neighbor 77.10.10.10 update-source TenGigabitEthernet0/0/4
 neighbor 80.10.10.10 remote-as 61000
 neighbor 80.10.10.10 description ***PEER-backup***
 neighbor 80.10.10.10 shutdown
 neighbor 80.10.10.10 ebgp-multihop 3
 neighbor 80.10.10.10 update-source Loopback0
 neighbor 90.10.6.18 remote-as 65000
 address-family ipv4
  neighbor 77.10.10.10 activate
  neighbor 77.10.10.10 soft-reconfiguration inbound
  neighbor 77.10.10.10 route-map Set_Local_Pref in
  neighbor 77.10.10.10 route-map BGP-PEER-EXPORT out
  neighbor 80.10.10.10 activate
  neighbor 80.10.10.10 soft-reconfiguration inbound
  neighbor 80.10.10.10 route-map ORANGE-BGP-PEER-EXPORT out
  neighbor 90.10.6.18 activate
  neighbor 90.10.6.18 next-hop-self
  neighbor 90.10.6.18 soft-reconfiguration inbound
  auto-summary
 exit-address-family
r1
router bgp 65000
 bgp router-id 90.10.6.1
 neighbor 77.10.10.11 remote-as 60000
 neighbor 77.10.10.11 description ***PEER-1***
 neighbor 77.10.10.11 update-source TenGigabitEthernet0/0/4
 neighbor 90.10.6.17 remote-as 65000
 address-family ipv4
  neighbor 77.10.10.11 activate
  neighbor 77.10.10.11 soft-reconfiguration inbound
  neighbor 77.10.10.11 route-map Set_Local_Pref in
  neighbor 90.10.6.17 activate
  neighbor 90.10.6.17 next-hop-self
  neighbor 90.10.6.17 soft-reconfiguration inbound
  auto-summary
 exit-address-family
R2
R2_8300#show route-map BGP-PEER-EXPORT
  Match clauses:
  Set clauses:
    community no-export
R2_8300#show ip access-lists  BGP-PEER-EXPORT
    5 deny   90.10.6.2
    10 permit 90.10.6.0, wildcard bits 0.0.1.255 (8 matches)
    40 deny   any (74980934 matches)
R1
  Match clauses:
  Set clauses:
    community no-export
    5 deny   90.10.6.2
Use  prefix list instead of Acl with route map Out
The acl is not so effect like prefix list to filter prefix.
Waiting your reply
MHM
