Bookmark
Subscribe
583
Limit bandwidth only to a specific port
kgtnewmedia
can someone point me out how to limit traffic to specific port on a C6k plattform?
Assuming there is a GE port. Traffic go through this port with destination to port 53 (DNS)
should be limiting to a maximum of 100 Mbps, all other traffic should be normally burstable
to full Gig. Thanks.
amabdelh
You will need to configure qos, if you can provide more details of the network and your config we can help you with this
thanks for your answer.
It is a Catalyst 6509-E with SUP720-3BXL and WS-X6724-SFP (with WS-F6700-DFC3BXL) running 15.1(1)SY1.
QoS is not enabled yet. Here is the config of the port:
interface GigabitEthernet8/1
 switchport
 switchport access vlan 700
 switchport mode access
 no cdp enable
interface Vlan700
 ip address 192.168.150.102 255.255.255.248
 ip verify unicast reverse-path 150
 ipv6 nd ra suppress
access-list 150 permit ip any any
Thomas
I've created two configs. Would one of these fit my requirements to limit inbound traffic on port 8/1 to a maximum
of 100 Mbps? (10% of the available port bandwidth)
mls qos
mls qos aggregate-policer udp_in_100mbps 100000000 2000 conform-action transmit exceed-action drop
access-list 120 permit udp any any eq dns
class-map match-all dns_qos
match access-group 120
policy-map dns_policy
class dns_qos
police aggregate udp_in_100mbps
interface Vlan700
ipv6 nd ra suppress
service-policy input dns_policy
mls qos
class dns_qos
police 100000000 2000 2000 conform-action transmit exceed-action drop
interface Vlan700
ipv6 nd ra suppress
