Line console 0 command
dbarboza27
Checking the configuration of a router, I found the following commands:
line con 0
access-class 1 in
exec-timeout 5 0
I don't understand the idea of the command access-class 1 in, untill now I have understand that the access-class is used to control the access by an ACL, but regarding the console, the connection is serial.
paolo bevilacqua
For "in" keyword, it's a minor incongruence, that can be disregarded.
For the "out" keyword, you can control to which destination it's possible to open connections.
Peter Paluch
Paolo,
Just a thought - could it perhaps be effective in controlling the access to a reverse telnet session? I have played very little with these things.
Best regards,
Peter
From what I know, one can only use TTYs for reverse telnet.
I have edited my post to better clarify.
dbarboza27
Thanks for your comments,
