line vty authentication question
gibsowe55
Hello - I'm wondering if I'll be able to access a pre-configured switch after deployment without TACACS credentials.  The line that reads login authentication *ACS username" (I've hidden the actual username) will this require TACACS?  Or will the access-cass sshin in command let me in with local enable password?
line vty 0 4
 access-class sshin in
 privilege level 15
 logging synchronous
 length 0
 transport input ssh
line vty 5 15
 privilege level 15
 logging synchronous
 login authentication *ACS username*
 length 0
 transport input ssh
Exactly. Test this locally before sending the switch off though...
'login authentication' under the VTY lines requires TACACS. Hoever, if you have 'local' configured in your aaa model, local enable password should work if TACACS is not available.
To be sure your config works, post it here in full...
Hi George - I found the line "aaa authentication login *ACS username* group tacacs+ local"
So you're saying the tacacs+ local portion will allow local login if tacacs isn't available?
