VPN on VPN!!! All hands on deck
Fotiosmark
Most particular request!
There a site to site VPN from a subnet  GWB 10.0.4.0 to GWA 192.168.1.0
That works plus internet all good.
Now, we connect an Access Point to the Cisco 886 and put a different private ip as 192.168.2.0 in Vlan10.
Wifi works fine.
Now, when people with in this Wifi try to connect to Remote VPN to the GWA (which is in a far far place) they cant ping anything within this network that VPN site to site can ping.
If they use a Wifi outside their office, it works.
I don't understand this at all. Any suggestions ?
most likely this is related to your access lists. Post the full running config of your router...
I agree with Georg that seeing the configurations (probably from both sides) will be helpful. And it would be helpful if the original poster would clarify the topology of the network. But based on what we know so far there is a question to address. If I am understanding correctly you are adding network 192.168.2.0 on the router. So the question is to verify whether the access lists used on both ends have been updated to enable access from this new network.
Rick
Rick
