Linecard unsupported on 7613 chassis
DatTX
Hi everyone
I have a problem that i don't know why linecards 7600ES-20G3C are not working when i inserted them to router 7613 chassis. I tried to upgrade IOS but it's still not working. show module.jpglog.jpg
Joseph W. Doherty
Your error messages note those cards are not supported in slots 1 to 8.
You do know, xx13 chassis, not every slot supports 40 Gbps, i.e. not all have dual fabric connections?
In @marce1000's second reference, Table 1, we find:
Switch-fabric connectivity Two 20-Gbps fabric channels Uses the Cisco 7600 Series 720-Gbps switch fabric for data forwarding; two fabric channels are used
BTW, unsure 6500 optimal usage applies to 7600, but in the 6500, mixing classic bus cards, like your 6148s and fabric only cards, degrades performance.
5 Replies 5
marce1000
 - Ref : https://andovercg.com/datasheets/cisco-7600-line-cards.pdf
Table 1-2 Cisco 7600 ES+ Line Card Supported Router Platforms
              7600-ES+20G3C All Cisco 7600 series routers except for the Cisco 7603 router
Refhttps://andovercg.com/datasheets/cisco-7600-series-ethernet-services-plus-20-40-gbps-line-cards-datasheet.pdf
  >...The line cards are compatible with the Cisco 7600 Series Supervisor Engine 720-3B/3BXL and Cisco 7600 Series
Route Switch Processor 720 (RSP720) and later.
                   Check if any of these info's can provide more insights.
 M.
thankyou
Joseph W. Doherty
Yes, i swap it to slot 9 - 12 and it works. But i have problem that it's diag status is minor error. Do you know how to fix it. I have tried to reset linecard but it's not work
Possibly a whole chassis reload or a power off/on reboot may eliminate the minor error.  (I recall on the 6500s, sometimes a full power off/on reboot is needed for all hardware to "play nice" together, especially if different variants of DFCs and/or sups are being used [e.g. Q. What happens when you mix different versions of the PFC3x and DFC3x? ].)
