Link down due to local/remote fault
bhilgenkamp
I'm curious what the difference is between the following log entries:
%IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/3/0, link down due to remote fault
%IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/3/0, link down due to local fault
What would be causes for remote and local faults? How are these determined?
Mark Malone
Hi can you post the full output for the interface please
show int t0/3/0
Not sure what software platform your running but there are known bugs for these alerts too
CSCun88935
Saves search parameters so query can be run again in the future
Search for:
Software:
Release:
Email Notification
"link down due to local/remote fault" message observed during local shut
CSCun88935
Description
Symptom:
A log message %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet2/0/0, link down due to local fault is seen while 10G interface is configured for admin down
when we do shut or "no shut" on a TenGig interface in ASR1k
Conditions:
Seen only for 10G interface.
Workaround:
None
Further Problem Description:
This is only a cosmetic issue in which a level 6 informational message is getting printed while shutting down a 10G interface.
Display of "link down due to local/remote fault" message during a "shut" is not expected and is fixed with the current ddts
Display of "link down due to local/remote fault" message during a "no shut" is expected since the 10G SFP Hardware first brings down the link and then comes back up, this is observed with the link interrupts generated by 10G Hardware. Thus, "link down due to local/remote fault" during "no shut" is expected.
Customer Visible
Notifications
Save Bug
Open Support Case
The resolution of this defect introduces a change in behavior, or additional functionality, over previous releases
Was the description about this Bug Helpful?
(2)
Details
Last Modified:
Jul 13,2017
Status:
Fixed
Severity:
3 Moderate
Product:
(1)
Cisco ASR 1000 Series Aggregation Services Routers
Support Cases:
6
Known Affected Releases:
(1)
15.4(1)S
Known Fixed Releases:
(5)
15.5(0.6)S
15.4(3)SN1
15.4(3)S1
15.4(3)S
15.4(2.17)S0.5
