kernel: Unable to handle kernel paging request + Fixing recursive fault but reboot is needed
FelixSin
Hello, I bought a RV325 Router (VPN Dual WAN Gigabit) just 1 month ago.
It seems to work fine, but it's the second time in JUST ONE WEEK that I see this error on the log:
CPU 0 Unable to handle kernel paging request at virtual address 0000000000000000, epc == ffffffff814b400c, ra == ffffffff814b3edc
CPU 1 Unable to handle kernel paging request at virtual address 0000000000000000, epc == ffffffff8154d394, ra == ffffffff814aa4a0
Fixing recursive fault but reboot is needed!
Anyone has seen/fixed a similar problem?
My PID VID: RV325-K9 V03
Firmware: v1.3.2.02 (2016-09-23, 15:17:06)
Thank you & kind regards
Francesco
Mark Malone
That looks like a bug in the underlying Linux os , needs an upgrade or downgrade if no upgrade path
It could be cosmetic too as you have seen no effect so far but whenever you see kernel in logs its an issue usually with the device or underlying software
Maybe give it a reboot to clear the processes incase any are stuck keep an eye on it see if it re-appears
Thank you Mark.
I will try to update the FW asap. I've also just seen that a new FW 1.4.2.15 has been released right now.
I'll keep you updated
See you soon
F
