link-flap error detected on Gi1/0/6
eng_adel273
Dear sir
Always the port  Gi1/0/6 is going down , after restarting the switch it is working for small period and become down  , it connected to PC ,
Please check the error  logs
INK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to up
Jun 29 07:57:27.064: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to down
Jun 29 07:57:41.650: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to up
Jun 29 07:57:44.345: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to down
Jun 29 07:57:51.213: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6, changed state to up
Jun 29 07:57:52.373: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to up
Jun 29 07:57:56.057: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6, changed state to down
Jun 29 07:57:57.064: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to down
Jun 29 07:58:37.172: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6, changed state to up
Jun 29 07:58:39.898: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6, changed state to down
Jun 29 07:58:48.545: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to up
Jun 29 07:58:52.785: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to down
Jun 29 07:58:54.222: %PM-4-ERR_DISABLE: link-flap error detected on Gi1/0/6, put ting Gi1/0/6 in err-disable state
which switch model is this on ? What is connected on that port ?
switch model 2960 , PC is connected to the port
could be a physical problem with either the port, the cable, or the NIC of the PC. You could try another port or change the cable. The log usually tells you what the reason is for the port being put in err-disable state...
Leo Laohoo
Do the following:
1. Command: test cable tdr interface Gi1/0/6;
2. Wait for approximately 5 to 7 seconds for the process to run;
3. Command: sh cable tdr interface Gi1/0/6; and
4. Post the complete output to #3.
