Link Redundancy between two Internet Link
jain.nitin
Level 3
Level 3
HI All, I have two internet links with two different subnets from a ISP. Now I have to use both the link for internet want to do load balance & want to configure redundancy between these links. I have two routers & two firewalls. Can any one help to configure it so that I can achieve redundancy & do load balancing between them. Remember I have two different public IP subnet from same ISP.
Ninja
5 Replies 5
alsayed
hello
I faced like this issues before;Jon.Marchel suggested me to use GLBP,SO GO WITH GLBP + NATING
10XS
Hi Nitin,
For load balancing the internet traffic, you can go for configuring policy based routing. Using policy based routing you can direct the packets to take different paths. This way you can also prioritise your traffic like giving preferential treatment to different traffic.
For more on PBR have a look these links -->
http://www.cisco.com/warp/public/732/Tech/plicy_wp.htm
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/qos_c/qcpart1/qcpolicy.htm
Hope this helps....
AbhisheK
Please rate helpful posts!!!
Danilo Dy
Hi, ask your ISP to do eBGP peer with you using private AS. First link will be primary for first subnet and the second link will be secondary for it. Second link will be primary for second subnet and the first link will be secondary for it. Distribute the two subnets to your hosts. This will make your incoming traffic load sharing using BGP and make your link redundant.
For outgoing, use GLBP in your routers as your firewall gateway. This will make your outgoing traffic load balance. http://www.cisco.com/en/US/products/ps6550/products_white_paper09186a00801541c8.shtml
I already did this thrice, it should work for you as well. If I have time tomorrow, I'll post a diagram how to do it :)
HI Thanks for your reply but I could not understand ur point. See I have got two diff-diff public subnet. & have two firewalls. Can you just give me detail explaination so that i can understand it better.
Thanks a lot.
Ninja
Check the attached diagram then read the link for BGP Load Sharing and GLBP below
BGP Load Sharing multiple sample
http://www.cisco.com/warp/public/459/40.html
GLBP
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t15/ft_glbp.htm
