link to hardware configuration tool
w951duu
Am trying to spec out a router for a particular network setup so I can request.  Isn't there a online tool that helps with this (configuration tool)?
whats the URL??
Thanks.
Collin Clark
There really isn't a flow chart that I know of. There is one for switches but I have never run across one for routers. You can either post your requirements here, contact your VAR and use their SE or contact your local Cisco SE and they can help.
I beleive this tool is what you need
https://apps.cisco.com/qtc/config/html/configureHomeGuest.html
Choose product family and go on with options
