link UPDOWN messages
roncro
Level 3
Level 3
I have a Cisco 2951 router and two Cisco 2960 switches.  I see some link messages on the switches that my router doesn't seem to be too happy about.
2024-09-10T08:40:50.406566-06:00 192.168.2.3 542: Sep 10 14:40:49.403: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to up
2024-09-10T08:40:50.406911-06:00 192.168.2.3 543: Sep 10 14:40:50.404: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
2024-09-10T08:41:22.599905-06:00 192.168.2.3 544: Sep 10 14:41:21.596: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to down
2024-09-10T08:41:22.600246-06:00 192.168.2.3 545: Sep 10 14:41:22.597: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to down
2024-09-10T08:41:34.496244-06:00 192.168.2.3 546: Sep 10 14:41:33.492: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to up
2024-09-10T08:41:34.496620-06:00 192.168.2.3 547: Sep 10 14:41:34.494: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
2024-09-10T13:41:57.639131-06:00 192.168.2.3 548: .Sep 10 19:41:56.622: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to down
2024-09-10T13:41:59.639699-06:00 192.168.2.3 549: .Sep 10 19:41:58.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
2024-09-10T13:42:34.633711-06:00 192.168.2.3 550: .Sep 10 19:42:33.628: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to down
2024-09-10T13:42:34.634050-06:00 192.168.2.3 551: .Sep 10 19:42:34.629: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to down
2024-09-10T13:42:47.012313-06:00 192.168.2.3 552: .Sep 10 19:42:46.007: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to up
2024-09-10T13:42:47.012700-06:00 192.168.2.3 553: .Sep 10 19:42:47.008: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
Any ideas on what could cause that?
thanks,
Ron
7 Replies 7
Richard Burts
Ron
You supply data without supplying any information about environment. Can you tell us what model (and perhaps what version of software) is running on the router? Can you tell us what model (and perhaps what version of software) is running on the switches?
Rick
roncro
Level 3
Level 3
this is what is on the switches (I think that is where the issue is)
#show version
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 16:56 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
South uptime is 12 weeks, 2 days, 12 hours, 33 minutes
System restarted at 03:50:40 UTC Sun Jun 16 2024
System image file is "flash:/c2960s-universalk9-mz.122-55.SE3/c2960s-universalk9-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-24PS-L (PowerPC) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1541Z371
Last reset from power-on
10 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 24:B6:57:4A:AA:00
Motherboard assembly number : 73-11908-06
Power supply part number : 341-0393-02
Motherboard serial number : FOC15403GP2
Power supply serial number : DCA1532U3EY
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C2960S-24PS-L
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC15393JNY
System serial number : FOC1541Z371
Top Assembly Part Number : 800-30945-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMGE00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960S-24PS-L 12.2(55)SE3 C2960S-UNIVERSALK9-M
Configuration register is 0xF
Hello @roncro ,
post also a
show cdp neighbors
what is connected on the affected port gi1/0/3 ?
 Is it a router interface ?
Hope to help
Giuseppe
here it is for both switches;
North#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
South
Gig 1/0/28 149 S I WS-C2960S Gig 1/0/28
ap2 Gig 1/0/16 172 T AIR-AP112 Fas 0
ap7 Gig 1/0/13 122 T AIR-AP123 Fas 0
ap8 Gig 1/0/15 161 T AIR-AP123 Fas 0
ap-shark-2 Gig 1/0/14 126 T AIR-AP112 Fas 0
Charon-2951.central-plex.us
Gig 1/0/24 131 R B S CISCO2951 Gig 0/1.1
AP-TM-W-F7C033 Gig 1/0/22 134 T AIR-AP112 Fas 0
South#show cdp neighbors
North
Gig 1/0/28 126 S I WS-C2960S Gig 1/0/28
ap6 Gig 1/0/6 172 T AIR-AP123 Fas 0
ap9 Gig 1/0/2 130 T AIR-AP123 Fas 0
ap-seismo Gig 1/0/12 129 T AIR-AP112 Fas 0
anasa.localdomain
Gig 1/0/24 129 T AIR-AP112 Fas 0
ap1.localdomain Gig 1/0/4 127 T AIR-AP112 Fas 0
Thanks for the cdp neighbor output. In the first switch I see a connection to router 2951 but in the second switch I do not see any router connection. Is that correct? Is that what you expected?
Rick
Hi Richard,
yes that is correct, the north switch is connected to the router, the south switch is connected to the north switch.
(btw:  I noticed that after changing the domain name from localdomain, to an actual/real domain name I have,  these messages are almost not occuring anymore,  only saww 2 over the past 12 hours or so)
Ron
In looking more carefully at this discussion I realize that we have a mistake in our understanding. We have been assuming that the issue is about the connection of switch to router. But looking at the OP the affected interface is GigabitEthernet1/0/3. That is NOT the connection to the router. So what is connected on that interface?
Rick
