LISP - override mapping received from MS/MR with a locally configured
kasper123
Level 4
Level 4
Hi all,
I have a working LISP implementation and everything is working as expected.
What I would like to do is override a mapping received from the MS/MR and use a locally configured mapping for an EID telling the router to encapsulate and send the traffic not to the RLOC received by the MS/MR but to another one which would be locally configured. Something like a Policy Based Routing that could override the mapping from the MS/MR.
Is this something that is doable?
kasper123
Level 4
Level 4
I managed to find the solution myself. If anyone stumbles upon this in the future:
To override the map cache we can manually add an entry that will be preferred over the one received from the MS/MR.
router lisp
instance-id 200
 service ipv6
  map-cache FD00:BF:1:1::10/128 FD00:10:10:255::1 priority 1 weight 100
Giuseppe Larosa
Hello @kasper123 ,
is it an SD Access scenario ?
Hope to help
Giuseppe
Hi Giuseppe,
No, no SD involved.
What I basically need is some LISP command to set the map cache locally and overriding what is received from the MS/MR.
Br.
kasper123
Level 4
Level 4
router lisp
instance-id 200
 service ipv6
Hello @kasper123 ,
very good news !
You have been very kind to provide the solution
thanks for feedback
Best Regards
Giuseppe
