Adding NAT for Internet users, breaks VPN user access
swiftsoft
I have a VPN from head office to remote office as follows:
Head office: 10.10.10.0/24   - Cisco ASA 5508
Remote office: 10.10.20.0/24   - Cisco 887 router
Currently users print from a server 10.10.10.15 to a printer 10.10.20.70 using tcp port 9101
We have a new required to allow 3 Internet IP address access to the same printer using port 65001
When I add the line below to the remote office router, I can no longer 'telnet 10.10.20.70 9101' from head office server 10.10.10.15
ip nat inside source static tcp 10.10.20.70 9101 interface Dialer1 65001
What I am doing wrong?
I assume I need to exclude the 10.10.10.0/24 network from the above NAT statement, but I don't know how to.
Thank you
Keith
with this line:
--> ip nat inside source static tcp 10.10.20.70 9101 interface Dialer1 65001
all traffic for the TCP port and IP address go out to the Internet. Indeed you need to configure NAT exemptions on both sides.
Can you post the configs of both the ASA and the 887 router ?
Hi Georg,
I have posted below the 887 router config. The ASA should be fine, as it works again if I remove the:
ip nat inside source static tcp 10.10.20.70 9101 interface Dialier1 65001
from the 887.
Thank you for having a look at this.
Keith
887 config:
version 15.5
service password-encryption
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ethernet lmi ce
ip dhcp excluded-address 10.10.20.70 10.10.20.254
ip dhcp pool LAN
network 10.10.20.0 255.255.255.0
default-router 10.10.20.254
dns-server 10.10.10.10 10.10.10.11
ip name-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn REMOVED
controller VDSL 0
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 2
lifetime 28800
crypto isakmp keepalive 180 periodic
crypto isakmp peer address REMOVED
set aggressive-mode password REMOVED
set aggressive-mode client-endpoint user-fqdn REMOVED
crypto ipsec transform-set HQset esp-aes 256 esp-sha-hmac
mode tunnel
crypto map HQmap 10 ipsec-isakmp
set peer REMOVED
set security-association lifetime kilobytes disable
set security-association lifetime seconds 28800
set transform-set HQset
match address 102
crypto map HQmap 20 ipsec-isakmp
set peer REMOVED
match address 103
interface ATM0
no ip address
shutdown
atm vc-per-vp 128
no atm ilmi-keepalive
pvc 0/38
oam-pvc 0
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
interface FastEthernet1
switchport access vlan 3
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport mode trunk
no ip address
interface Vlan1
ip address 10.10.20.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Vlan2
ip address 10.2.20.254 255.255.255.0
ip nat inside
interface Vlan3
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname REMOVED
ppp chap password REMOVED
crypto map HQmap
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.0.9 3388 interface Dialer1 3388
ip nat inside source static tcp 192.168.0.9 5611 interface Dialer1 5611
ip nat inside source static tcp 192.168.0.9 5552 interface Dialer1 5552
ip nat inside source static tcp 192.168.0.9 5553 interface Dialer1 5553
ip nat inside source static tcp 10.10.20.230 22 interface Dialer1 22
ip route 0.0.0.0 0.0.0.0 Dialer1
ip sla 100
icmp-echo 10.10.10.250 source-interface Vlan1
ip sla schedule 100 life forever start-time now
ip sla 101
icmp-echo 10.10.60.2 source-interface Vlan1
ip sla schedule 101 life forever start-time now
ip sla 102
icmp-echo 10.10.200.67 source-interface Vlan1
ip sla schedule 102 life forever start-time now
dialer-list 1 protocol ip permit
snmp-server community public RO
access-list 101 deny ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 101 deny ip 10.10.20.0 0.0.0.255 10.10.60.0 0.0.0.255
access-list 101 deny ip 10.10.20.0 0.0.0.255 10.10.200.0 0.0.0.255
access-list 101 permit ip 10.2.20.0 0.0.0.255 any
access-list 101 permit ip 10.10.20.0 0.0.0.255 any
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 102 permit ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 102 permit ip 10.10.20.0 0.0.0.255 10.10.200.0 0.0.0.255
access-list 102 permit ip 10.2.20.0 0.0.0.255 10.10.2.0 0.0.0.255
access-list 103 permit ip 10.10.20.0 0.0.0.255 10.10.60.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
password REMOVED
login
transport input all
scheduler allocate 20000 1000
ntp server 109.74.206.120
Hi Georg,
Below is the config from the 887 branch office router.
The head office ASA should be fine, as I have not changed anything there. If I remove the
the printing from head office is restored.
Thank you for having a look at this issue.
Keith
version 15.5
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ethernet lmi ce
ip dhcp pool LAN
ip cef
no ipv6 cef
controller VDSL 0
encr aes 256
group 2
lifetime 28800
mode tunnel
set peer REMOVED
match address 102
set peer REMOVED
match address 103
interface ATM0
no ip address
shutdown
atm vc-per-vp 128
pvc 0/38
oam-pvc 0
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
interface Vlan3
ip nat inside
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
crypto map HQmap
no ip http server
ip sla 100
ip sla 101
ip sla 102
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password REMOVED
login
transport input all
My reply keeps getting deleted!
The 887 config is below. I have removed public IP addresses and passwords.
ip dhcp pool LAN
ip cef
no ipv6 cef
controller VDSL 0
encr aes 256
group 2
lifetime 28800
mode tunnel
set peer REMOVED
match address 102
set peer REMOVED
match address 103
interface ATM0
no ip address
shutdown
atm vc-per-vp 128
pvc 0/38
oam-pvc 0
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
interface Vlan3
ip nat inside
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
crypto map HQmap
no ip http server
