LLQ: confusing "debug priority" output
mogli
hello,
we've got an installation at a customer with two sites connected via a 1Mbit/sec serial link using llq for voice priorisation. after having problems with the voice quality and debugging around i a get very interesting output when using the "debug priority" command:
26w2d: now 3093345544 tokens 95488 pak_size 592 max_token_limit 100000
26w2d: now 3093345544 tokens 94896 pak_size 592 max_token_limit 100000
26w2d: now 3093345544 tokens 94304 pak_size 592 max_token_limit 100000
26w2d: now 3093345548 tokens 95712 pak_size 592 max_token_limit 100000
26w2d: now 3093345548 tokens 95120 pak_size 592 max_token_limit 100000
26w2d: now 3093345548 tokens 94528 pak_size 592 max_token_limit 100000
26w2d: now 3093345548 tokens 93936 pak_size 592 max_token_limit 100000
26w2d: now 3093345548 tokens 93344 pak_size 592 max_token_limit 100000
so after reconfiguring the match clause for my priority queue the voice problems stop, but the messages still appear.
now my question: does these debug output actually show a problem or is this a normal output from this debug command?
the only references i found regarding this output where in combination with following lines:
3d01h: WFQ: dropping a packet from the priority queue 1
but in my scenario this information that a packet from the pq has been dropped never appears.
never mind, every idea how to handle the first shown output is very welcome!
thank's for your time,
kind regards,
bernhard
Not applicable
