LLQ on Gre Tunnel Interface with Traffic Shaping
bapi_italy
I have the following requirement. My HQ Hub router has 20 Mbps of BW having several GRE tunnels to branches with 512 Kbps, for each branch except two  branches, having 2 Mbps of BW each. Some branches are using IP phones and also accessing critical resources from the HQ. Now, instead of applying the policy-map on the egress physical interface of the the HQ router, I have applied it on the tunnel interface with Nested QOS,( Parent and Child policy as per Cisco Documents). However, I am unsuccessful in limiting the email traffic through the tunnel to the branches, They consume the entire BW of the 512 tunnel. When I issue the command show policy-map interface tunnel x, I clearly see the email traffic  hitting  the class-map confiration, but I can not limit the email flow. I do not want to apply the policy-map command on the physical interface because all my tunnels are not using uniform BW of 512 Kbps.Can anybody share his experience.
12 Replies 12
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
I've found shapers a bit "quirky" when supporting VoIP.  Some things that might help include insuring the shaper's Tc is 10ms or less, and often allowing for L2 overhead in your shaped for bandwidth (512 Kbps L2 isn't the same as 512 Kbps of L3).
If you post your policies (HQ and branch), I might be able to offer additional suggestions.  (Also note IOS version(s) being used.)
Hi Joseph
Please find the configuration
class-map match-all VOICE
match protocol rtp audio
class-map match-any LowPriority
match access-group name LowPriority-Traffic-ACL
match access-group name EMAIL-Traffic-LnG
policy-map TRAFFIC-SHAPING
class VOICE
    priority percent 15
class LowPriority
    bandwidth 96
policy-map WAN-EGRESS
class class-default
    shape average 512000
  service-policy TRAFFIC-SHAPING
interface Tunnel36
bandwidth 512
ip nbar protocol-discovery
service-policy output WAN-EGRESS
interface GigabitEthernet0/1
description 20 MB MPLS towards service provider
bandwidth 20000
#show ip access-lists EMAIL-Traffic-LnG
Extended IP access list EMAIL-Traffic-LnG
    10 permit ip host 172.20.12.31 10.32.0.0 0.0.255.255 (6530 matches)
#show ip access-lists LowPriority-Traffic-ACL
Extended IP access list LowPriority-Traffic-ACL
    10 permit ip host 192.168.200.86 any (451939 matches)
    20 permit ip host 192.168.200.137 any (104342 matches)
    30 permit ip host 192.168.200.128 any (193038 matches)
#show policy-map interface tun 36
  Service-policy output: WAN-EGRESS
    Class-map: class-default (match-any)
      1025886 packets, 193365310 bytes
      5 minute offered rate 90000 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/83/0
      (pkts output/bytes output) 1013777/196897525
      shape (average) cir 512000, bc 2048, be 2048
      target shape rate 512000
      Service-policy : TRAFFIC-SHAPING
        queue stats for all priority classes:
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 2424/228424
        Class-map: VOICE (match-all)
          2424 packets, 194488 bytes
          5 minute offered rate 0 bps, drop rate 0 bps
          Match: protocol rtp audio
          Priority: 15% (76 kbps), burst bytes 1900, b/w exceed drops: 0
        Class-map: LowPriority (match-any)
          194813 packets, 18812918 bytes
          5 minute offered rate 7000 bps, drop rate 0 bps
          Match: access-group name LowPriority-Traffic-ACL
            187868 packets, 14329125 bytes
            5 minute rate 0 bps
          Match: access-group name EMAIL-Traffic-LnG
            6945 packets, 4483793 bytes
            5 minute rate 7000 bps
          Queueing
          (pkts output/bytes output) 194696/21361226
          bandwidth 96 kbps
          828649 packets, 174357904 bytes
          5 minute offered rate 76000 bps, drop rate 0 bps
          Match: any
          (pkts output/bytes output) 816657/175307875
Hi Joseph
I forgot to put the IOS version which is c3900-universalk9-mz.SPA.150-1.M1.bin in HQ. What I want is that during congestion or anytime, the email traffic or any other low priority traffic should not take more than 96 Kbps out of 512 and meanwhile, for voice, at present I have deployed only one phone for testing to consume only 76 Kbps including layer 2 and 3 payloads for a codec of G.729. As you can see from my previous post, I am able to capture the voice and low priority traffic in the service policy, however, the entire BW is consumed when the user starts to download email attachement from the branch over the WAN link. My question is whether  servie policy is  able to shape  the email traffic which enters the tunnel and gets encapsulated by GRE
Disclaimer
Posting
The bandwidth statement provides a miminal bandwidth guarantee, not a maximum restriction.  If you want to restrict your low priority traffic, you migh try:
class VOICE
    priority percent 15
class LowPriority
    bandwidth 96
    police 96000
Dear Joseph
Thanks a lot for your suggestion. I will apply it on monday and get back to you
Dear Joseph
I would sincerely thank you very much for the above solution, it worked, however, I have the following doubts need to be clarified if you do not mind.
1. Since, traffic shaping is not possible on child policy under Parent Policy  applied on the tunnel interface,  therefore, we are  Policing. Now, while  policing, the excess traffic is dropped unlike traffic shaping where access traffic is buffered. Will the dropped packets be resent ? and I also see lot of output drops on the tunnel interface
2. I am lillte confused many a times with QOS, may be due to lack of understanding of the concept. As per my scenario, the branch users require to connect to citrix servers in the HQ for example, in this scenario should I apply QOS with some bandwidth allocation on the egress tunnel interface of the HQ Router 512 Kps link or also on the BR Router's either tunnel or physical interface with qos pre-classified confiured on the branch tunnel, as per my logic resources lie on the HQ so I may only need to apply the QOS on the HQ tunnel interface unless I have some voip traffic from both end.
Disclaimer
Posting
Depends on the nature of the traffic.  TCP should resend, others vary.
#2 Generally you want to apply QoS where there is likely to be congestion.  In your topology, most likely bottleneck is the branch link.  On the HQ side we shape to match the bandwidth only because we're unable to place QoS on provider's side of branch link.  On branch, assuming 512 is the physical bandwidth, we apply to physical interface.  If logical cap, we would need to shape there too.
Pre-classify is needed if we have QoS applied on physical interface, supporting tunneled traffic, which we want to "examine".
Since you now mention working with Citrix, for that traffic (especially for the screen scraping, subtype 1), for good performance, you often want to provide it better priority than normal traffic.
Here's a generic policy that works well if you direct traffic to the correct class.
policy-map Generic
class real-time
priority percent 30
class foreground
bandwidth remaining 81
fair-queue
class background
bandwidth remaining 1
fair-queue
class default
bandwidth remaining 9
fair-queue
In the above, you might place Citrix in "foreground" and email in "background".
The bandwidth percentages are chosen for scheduling priority, actual bandwidth usage should be the inverse.
Thank you joseph
Dear Joseph. I have another doubt to be cleared. Please look at this example below
Class-map   Priority-CM
match access group name Foreground-ACL
ip access-list extended Foreground-ACL
10 permit ip host 10.70.1.12 host 192.168.241.2
20 permit ip host 10.20.14.3 host 192.168.217.4
30 permit ip host 10.21.15.100 host 192.168.218.10
Policy-Map WAN-QOS
class Priority-CM
bandwidth percent 40
In the above ACL suppose I have a match for the line 10,20,30 then which line will execute first ? is it the line 10 first because it is matched first ? however, I want all the traffic matched in line 10,20 and 30 needs to be affected
Disclaimer
Posting
Each of your ACLs are against specific src/dest hosts.  Matching against one precludes matching against another.  Logically all three will be effective, and also logically, their sequence doesn't matter.  (Physically, there may better to sequence them in match count order.)
In one of the tunnel interface, when I apply the QOS command it gives the following message.
MAIN-R1(config-if)#service-policy output WAN-QOS
Insufficient bandwidth 1024 kbps for bandwidth guarantee
please remove queuing feature from child policy first
I need the hierarchical policy for tunnel interface which is working fine for other tunnels in the same router
Disclaimer
Posting
The error message tells us that the device believe you're over allocating bandwidth.  As you didn't provide a complete posting of your configuration, difficult to be more helpful.
