problem with MPLS link bandwidth
we have 3 branches connected to headoffice over mpls with the speed of 2 MBPS each, and all were working fine with 30 to 40 users at branch and voip system. but one branch experiancing bandwidth problem as other two are working fine.
when i am pinging from headoffice system to branch router or vice versa the ping time is too high.
but when i connect my laptop to mpls connection at branch by removing the cable from router and ping to HO router , the time is 5 to10 ms
but when i connect it to router and ping from internal netowrk the time is varying between 5 to 300 ms.
thers is no problem with internal network as from internal network  to isp gatway ping time is netween 5 to 20 ms
the config is like below..
HO tunnel config (IP 192.168.12.5)
interface FastEthernet0/1
description " Connection to ISP MPLS"
ip address 172.31.3.18 255.255.255.252
duplex full
speed 100
interface Tunnel102
description " Tunnel RYD-NAS "
bandwidth 1024
ip address 10.10.0.10 255.255.255.252
tunnel source 172.31.3.18
tunnel destination 172.31.197.18
router eigrp 200
redistribute ospf 10 metric 512 600 100 100 1500
network 10.10.0.0 0.0.0.3
network 10.10.0.4 0.0.0.3
network 10.10.0.8 0.0.0.3
network 10.10.0.28 0.0.0.3
no auto-summary
router bgp 65412
no synchronization
bgp log-neighbor-changes
bgp redistribute-internal
network 10.10.10.0 mask 255.255.255.0
network 192.168.21.0
network 192.168.31.0
network 192.168.33.0
network 192.168.41.0
redistribute ospf 10 match internal external 1 external 2
neighbor 172.16.16.1 remote-as 29684
neighbor 172.16.16.1 prefix-list only-lan out
neighbor 172.31.3.17 remote-as 65000
neighbor 172.31.3.17 prefix-list only-lan out
no auto-summary
Branch config (IP 192.168.40.5)
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 192.168.40.5 255.255.255.0
ip address 172.31.197.18 255.255.255.252
duplex auto
speed auto
interface Tunnel102
description " Tunnel NAS-RYD "
bandwidth 1024
ip address 10.10.0.9 255.255.255.252
tunnel source 172.31.197.18
tunnel destination 172.31.3.18
router eigrp 200
network 192.168.40.0
router bgp 65412
no synchronization
neighbor 172.31.197.17 remote-as 65000
no auto-summary
ping result from head office system to branch router
Bilal Nawaz
Hello, it sounds like maybe 2mb is not enough for this branch in particular - maybe someone or something is using bandwidth a little more excessively somehow than the other branches, 30 - 40 people sharing 2mb sounds a little less.
But maybe thats because we all enjoy the super speed broadband at home these days.
Lets look at it this way. All users are going via the router. When you take that cable from the MPLS CE router and plug in to your laptop, it's only you who has that full 2mb bandwidth available. You are not sharing any traffic with anyone else who may be in the branch.
If you are able to 'ping' and there is connectivity as expected, there probably isnt wrong with your config. What if you try connecting to your router, and have your laptop only plugged in to your router.
e.g.
MPLS CE ROUTER ------- YOUR ROUTER ------ YOUR LAPTOP ONLY
Test this and see what kind of latency you get. If its approx 10 - 50 ms its good. That means maybe its something in the LAN that is taking up B/W. If its greater than that, then we know that maybe something is wrong with the router itself.
Have you tried monitoring tools like SNMP and Netflow? This way you can see link utilization, average bandwidth etc... Also with netflow you'll be able to tell if its a particular protocol, source, destination, and how much data has been transfered, which may show the reason for this slowness.
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
e.g.
Hope this helps
Thank you Mr.Bilal,
I am at head office at present and will check after finishing the work here.
hope this will work fine,but we have 2 mbps link for all branch and 6 mb at head office but why this perticular branch giving problem.
anyway i have to test it....
Thankyou once again
Hi mate,
I also suggest you run winmtr for at least 10-20 minutes and post the results; this way you will be able to identify the congested hop.
Hi Florin,
Thank you for the mail,
The issue got solved, the problem was with the PCs connected.
we had the PSTs located at head office, and the PCs were having virus also, so when they are accessing outlook over the network it was consuming all the bandwidth, so the pings were going high and the voice traffice was getting affected.
we shifted the PSTs to local systems and installed new anti virus in all the branch systems.
now the ping time is 5ms, that is good for me..
Thank you all.
