LMS 3.1 Windows - TFTP server
chris.mcgarrah
Can the TFTP server installed by CiscoWorks be accessed outside of the application. When I try to send a config to the CiscoWorks server manually from a switch, I get a message:
%Error opening tftp://wdcma215/rtpwdc-bir-sx01-confg (Permission denied)
Can it be enabled to be accessed? Read-only would be OK. Thanks.
Giuseppe Larosa
Hello Chris,
try to create the file before with the same name and give it rights to be read and written by everyone
Otherwise you need to use another TFTP server.
Hope to help
Giuseppe
