Load Balance / Failover Scenario
Amin Shaikh
I have Two DSL connection with Static Public-IP-address terminated on a 3640 Router and need help in configuring load-balancing and failover of links and services.
Would like to run the following services
1. Internet browsing
2. Client VPN
3. SMTP Gateway
4. Natted IP to access Server
IS there a cisco sample config for my requirement.
Currently all are working on a single DSL connection...
ajay chauhan
Level 7
Level 7
I think you can loadbalance in this situation by using NAT half of your network you can map with one DSL provider and rest you can nat with another DSL provider.
Thanks for your reply.
But this is not load balance solution,
I m looking or some advance load-balancing & failove solutions....
