10-09-2017 08:06 AM - edited 03-05-2019 09:16 AM
I am unabel to find an example of how to LB service between 2 servers using a 3750.. It seems etherchannle sis mostly for switch to switch.. Does anyone have an example config?
1 IP to 2 servers?
10-09-2017 08:57 AM
10-09-2017 09:38 AM
Yes this i've read my dilema is when creating the port-channel you give it an ip address and you configure the LB ports with channel-group but on server side what ip' addess is given to NIC's
cisco IP.? Server1 IP? etc
WWW---> cisco------>server1 NIC
------->server2 NIC
10-09-2017 09:49 AM
Could you not use a layer 2 port-channel on switch side , add the the vlan to the etherchannel po and its member ports and then give the server nics ips in that vlan range and then set the LB on server side another option
i persume if your going l3 the nics would need to be in that po subnet range you use on switch side so they can communicate and subnet then routed , our server or chassis based blade servers are all done in L2 and trunked up to the core then routed there at the l3 vss
10-09-2017 09:53 AM
I know how to LB using proxy;s etc I was hoping cisco could LB internaly.
10-09-2017 10:01 AM
