Load Balance with CEF and 2 Ethernet WAN ports
randy
Not able to get load Balance out. Can you Please tell me what I am doing wrong? Thank you!!
version 12.4
resource policy
no network-clock-participate slot 1
ip cef
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
ip nat inside
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
ip address 24.49.X.X 255.255.255.0
ip nat outside
speed auto
full-duplex
interface FastEthernet1/0
ip address 24.54.X.X 255.255.255.0
ip nat outside
speed auto
full-duplex
ip route 0.0.0.0 0.0.0.0 24.49.199.1
ip route 0.0.0.0 0.0.0.0 24.54.119.1 10
ip nat inside source list 120 interface FastEthernet0/1 overload
ip nat inside source list 121 interface FastEthernet1/0 overload
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
access-list 121 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
control-plane
6 Replies 6
Jon Marshall
Randy
If you want this to load-balance then you need both default-routes in the routing table but you have applied an AD of 10 to your second default-route so if you do a "sh ip ro" you will only see the default-route via 24.49.199.1.
If you want to load-balance then you need both in the routing table ie. change this is in your config, from -
to
Jon
Jon,
That's what I was thinking but, when I remove the 10 nothing will route to the internet from 0/0. In other words it just stops working.
Any ideas?
more info.. I can shut either 0/1 or 1/0 and ping out so, i know the service on both ports is working. I can set 0/1 as default and reach the net but if I try to set 1/0 as default.. no go. it's like I have a routing problem between 0/0 and 1/0. 0/0 and 0/1 are on one card and 1/0 is on another.. is there a problem in the way I'm using the ports? should I be using 1/0 as my LAN and 0/0 and 0/1 as my WAN's? I did not think mattered
Thanks!
Randy
Randy
I'm not aware that there are problems with the order you use the cards.
If you could do this test -
1) set default-route via 0/1 and ping from a 192.168.1.x client to the internet. Then run "sh ip nat translations" and post here
2) set default-route to 1/0 and ping from same client. run "sh ip nat translations" again. If ping works let me know. If ping doesn't can you then "clear ip nat translation *" and then try ping again. If it works post "sh ip nat translations".
Note "clear ip nat translation *" will break any connections through the router so either test out of hours or you can be more specific and clear only the specific NAT translation.
Jon
Hi Randy,
as Jon mentioned above yo have to have two default routes each point to one of your ISPs
and those default routes have to be installed in the routing table then you can get CEF to load balance the traffic ( per session by default )
however, you need to updated your NATing config so that it mach the relevant exit interface of each NAT statement using a route-maps otherwise the IOS will keep use the first NATing regardless which interface is the exit point !
refer to the bellow document, i posted before on CSC which will gudie you step by step to achive what you looking for
and you might want to consider IPSLA and PBR ( optional ) for reliable fallback
https://supportforums.cisco.com/docs/DOC-8313
if helpful Rate
Marwan
Good point about the route-maps +5
Jon
Thanks Jon
