NM-1T3/E3 - 8 MB DS3
rajivrajan1
Level 3
Level 3
Hi All
we have a NM-1T3/E3 card. WE are getting a sliced DS3 ( i.e . Channelized ) from Verizon. but his card doesnt seems to be supporing any channelization.
Can I just use DSU bandwidth 8000 ? will this work ? , Can anyone please let me know if you have used this card for reduced rated ( channelised ) DS3 ?
PLease let me know if anyone have the information.
Show diag output
NM-1T3/E3 (clear/subrate) Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time 00:24:05 ago
EEPROM contents at hardware discovery:
Hardware Revision        : 1.0
Top Assy. Part Number    : 800-19180-03
Board Revision           : B0
Deviation Number         : 0-0
Fab Version              : 03
PCB Serial Number        : FOC15170MKL
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Calibration Data         : Minimum: -1 dBmV, Maximum: -1 dBmV
The local interface configuration must match the remote interface configuration. For example, if you reduce the maximum bandwidth to 16000 on the local port, you must also do the same on the remote port.
The dsu bandwidth command reduces the bandwidth by padding the E3 and T3 frame.
To verify the data service unit (DSU) bandwidth configured on the interface, use the show controllers serial EXEC command.
DSU bandwidth
gcmills
Not sure of your router type but, be sure the IOS supports that particular NM. That aside, essential commands that I've found are:
-global
Card type t3 1 *the last # is slot
Controller t3 1/0. *takes you into controller configuration. This is where you'll set framing, clock source & line code
To set fractional speed, you'd use the:
dsu bandwidth xxxxxx
Last thing, ensure to have enough DRAM
