Load balancing across ATM interfaces in a bridge-group.
jlixfeld
I have two WIC-1ASDL interfaces in a 2651 running 12.3(26). Do I need to do any other magic to get load-sharing to work across the two ATM interfaces grouped into the BVI?
ip cef
bridge irb
interface ATM0/0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
bridge-group 10
pvc 0/35
encapsulation aal5snap
interface ATM0/1
no ip address
bundle-enable
bridge-group 10
pvc 0/35
interface BVI10
mac-address 0006.d780.a6a0
ip address 172.20.16.10 255.255.255.0
ip load-sharing per-packet
bridge 10 protocol ieee
bridge 10 route ip
Router#sh ip route | i 0.0.0.0
Gateway of last resort is 172.20.16.1 to network 0.0.0.0
D*EX 0.0.0.0/0 [170/5130496] via 172.20.16.1, 00:09:35, BVI10
Router#sh arp | i BVI10
Protocol Address Age (min) Hardware Addr Type Interface
Internet 172.20.16.10 - 0006.d780.a6a0 ARPA BVI10
Internet 172.20.16.1 9 0002.b3a0.0e6e ARPA BVI10
Router#
Router#sh int | i protocol|packets/sec
ATM0/0 is up, line protocol is up
5 minute input rate 7000 bits/sec, 12 packets/sec
5 minute output rate 13000 bits/sec, 19 packets/sec
ATM0/1 is up, line protocol is up
BVI10 is up, line protocol is up
5 minute input rate 8000 bits/sec, 12 packets/sec
5 minute output rate 11000 bits/sec, 19 packets/sec
Router#
Giuseppe Larosa
Hello Jason,
if STP is blocking the second ATM you cannot achieve load-balancing in this way.
verify with show spanning-tree the state of the two atm ports chances are that the second is not in forwarding state.
I would use two separate bridge-groups and two distinct BVIs. Then you add a second default static route using the second BVI so you can get load-balancing at L3.
Hope to help
Giuseppe
