load balancing and automatic failover between two isp on Cisco 1841
afernandez0226
hi all,
I have 2 Internet links (T1 and DHCP cable modem) need sample config to
load balancing and automatic failover between the two isp on Cisco 1841
JORGE RODRIGUEZ
Level 10
Level 10
Have a look at this link
IOS NAT Load-Balancing - OER
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
Jorge Rodriguez
Thanks for the quick reply. I was looking at this article but am confuse on this line that only show route over just 1 ISP; so why there is not a route for the 2nd ISP
ip route 0.0.0.0 0.0.0.0 dialer 0 track 123
Sometime the example configurations are not 100% correct. You can use the feedback form on the side to tell cisco about the mistakes.
