Load Balancing between two leased lines
raju
We have two leased lines to our branch office, each 128 K. Currently, we are using primary link as active and secondary link as Redundant. In case of primary link is down, we need to change the static Routes manually pointing to secondary link. Can we do the Load balancing between two links and when Primary goes down, secondary link should take over automaticcaly for all operations. When the primary link comes back, both the links should do Load balancing. We are using EIGRP as Routing Protocol.
thisisshanky
Level 11
Level 11
You can multilink between the two links so that even if one link fails, you will still have other link routing traffic, and when both links are up, you get effectively 256k bundle.
Here is an example of bundling multiple links.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_configuration_example09186a00800a5efa.shtml
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for your reply. FYI, both the links are terminating in two separate Routers and Router model is 1700 series with IOS 12.1(5r)T1.
in your case, with two routers, I think you are looking for Multichassis Multilink PPP, check this document for configuration details:
Configuring Multichassis Multilink PPP
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800a86a1.html
HTH,
GP
Thanks GP. Herewith , I'm attaching the simple format of our NW setup how the two sites (HQ & Branch office ) are connected.
