Load Balancing doubts
cisco
I am having doubts regrding load balancing , so i am summarising all the scenario . Kindly share your inputs
load balancing of user data from LAN towards WAN
Scenario 1) one router connected to a SP with dual links
Solution) By default it will be achieved by Per-Destination Load Balancing
Scenario 2) one router connected to 2 SPs
Solution )HSRP can be also used or ONLY BGP can be used ? if BGP, then which attributes can be used ?
Scenario 3) Two router connected to single SPs
Solution) HSRP/VRRP/GLBP
Scenario 4) Two routers connected to 2 SPs with single link each
Solution) Only BGP?
regards
Neo
Marwan ALshawi
Good question !
first of all you need to understand that from the router/routing point of view there is no difference if the multi homing with one or two differnt ISPs ( expect for some BGP attributes )
- if  you have router connected to a certain ISP/ISPs with dual links then first of all you need to make sure that in you RIB/routing table you have two equal cost ( unequal support with EIGRP) routes using both interfaces
like two default routes each one using diffrent links
- if the routing protocol is BGP then you need to enable the max eibgp multipath command ! to let the BGP install multiple paths for one routing ( assuming all other BGP attributes are equal ! )
- if you have two routers in your end and yu want to use HSRP/BLBP then here you are not using the routing protocol for load balancing or per destination algorithm however you are relaying of FHRP like HSRP or GLBP to load balance or share the traffic, which is diffrent concept
wish this will help you understand it in high level
good luck
if helpful Rate
After reading your response , i have reached to this conclusion (My understanding marked with *)
* If i have two equal cost links then its possible. This solution is fine
*HSRP can't be used , BGP will be used where i have to enable the max eibgp multipath command and to let the BGP install multiple paths .
*This is possible , but same routing table should be there on both the routers.
Solution) Only BGP?
* I didnt get the solution for this
regards
Neo
Hello Marwan,
nice to see you again in the forums
in order to install BGP routes coming from two different ASes/ISPs an hidden command is needed when dealing with standard eBGP sessions ( address-family ipv4 unicast)
bgp bestpath as-path multipath-relax
as explained in several posts in the forums
see
https://supportforums.cisco.com/message/790535#790535
for original poster:
scenario 1) : maximum-paths 2 under router bgp is enough, if the router is only one no need for HSRP/VRRP/GLBP on the internal interface
scenario 2) described above needs two commands on border router. Again
scenario 3) iBGP session between border routers help
scenario 4) requires eBGP sessions and iBGP session between the border routers
Hope to help
Giuseppe
Marwan ALshawi
Thanks Giuseppe I was busy with work
You right about bgp commands but I just provided quick high level description
One important think for the original post is that you need to distinguish between routing and fhrp like hsrp they are different protocols and concept !
for having loadbalancing with two routers each connecting to a different ISP u can use cisco performance routing PfR
Each routing protocol has different configuration for multipathing however they almost share the same concept and logic except with EIGRP as it support unequal cost lb
Wish this will help you
