02-18-2012 09:02 AM - edited 03-04-2019 03:19 PM
I have a 1841 router having 2 ISP links , till now I have been using IP SLA for NAT Failover but now I want to use OER to do Load Balancing and utlize both of my internet links . I went through an article which tells me of the configuration part however It only has 1 default route . In a case where that ISP goes down all traffic will be moved to other ISP link but there is no static default route for that ISP . Following is the article Link
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
Also is this the same type of technique other vendors including Baracuda , Tp-link etc work on Internet load balancing ?
02-20-2012 02:11 AM
I tested the setup using 2801 router however there were IP SLA faliures with both links . When i used default static route ( after removing track route ) i could get ping from 4.2.2.2 but with track it showed up as a faliure .
Attached is configuration and following are results of show commands
LoadBalancer#sh ip sla statistics
Round Trip Time (RTT) for Index 1
Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: *02:21:47.415 UTC Thu Jan 1 1970
Latest operation return code: Timeout
Number of successes: 0
Number of failures: 271
Operation time to live: Forever
Round Trip Time (RTT) for Index 2
LoadBalancer# sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/24 is subnetted, 1 subnets
C 10.2.2.0 is directly connected, FastEthernet0/1.2
C 192.168.1.0/24 is directly connected, FastEthernet0/1.1
