Load balancing of the forward traffic using Route map
My scenario goes like this:-
I have 3 Internet links from 3 different providers. I am running BGP on two of the links.But my default route of the router is pointing to the third link. I am controlling the forward traffic of a particular segment using the route-maps.In the route-map, i have configured two next-hop ip address. But the forward traffic is flowing thru only the fisrt next hop address and not thru the second one. My objective is to loadbalance the forward traffic matching the route-map criteria on both the next-hop addresses.
Pls let me know how can i achieve this.
rohit_agarawal
can u send me confguration n ur requirment
Route-map works like that.If you specify two different interfaces , it would choose the first one and in case of failure it would choose the other one and fallback to original setup if the first one is up
Create another sequence and set the second interface as next-hop for loadbalancing the traffic.
ref :
http://www.cisco.com/en/US/products/ps6599/products_white_paper09186a00800a4409.shtml#wp14045
Hope this helps
regards
vanesh k
