DHCP
navneet_78
How do i forward DHCP requests to a DHCP server from a Router?
Appreciate your quick response
Navneet
ankbhasi
Hi Navneet,
You need to use "ip helper-address" command specifying the ip address of the dhcp server on the interfaces from which you want to forward the DHCP request.
To enable the forwarding of User Datagram Protocol (UDP) broadcasts, including BOOTP, received on an interface, use the ip helper-address command in interface configuration mode.
To read more about this command have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tiad_r/adressht.htm#wp1135857
Ankur
mahmoodmkl
Level 7
Level 7
Configure ip helper-address under the interface of the router from where you want to forward the DHCP requests.the helper address should be of the dhcp server.
Mahmood
Thnx mahmood.
Regarda Navneet
ankbhasi
Hi Navneet,
Ankur
Thnks Ankur
