Load balancing on 2 Links..
gauravm
hi ,
i have 2 links to the same destination.one is 64kbps and other being 128 Kbps.
i want to do load balancing on the same link.
Could anyone tell me how to do it ??
fkoperdraat
On CCO do a search for "load balancing". The first result will point to a document with the title "How Does Load Balancing Work?", with Document ID 5212.
This will answer your question.
Sucess
Frank Koperdraat
amit-singh
Level 8
Level 8
We can do it in 2 way.
1. If you are running routing protocols like IGRP or EIGRP, they both support unequal cost path load balacning and they will do the load balancing across the link.
2. You can use multi-link PPP to do the load balancing for you. please refer the link below.
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a0080112d3b.shtml
HTH,
-amit singh
