load-balancing on Router 1841
join_sn09
Dear All,
I would like to ask you, i want to configure load-balance i mean when ISP 1 down automatically switch to ISP 2. Pleas see in the attach file.
Could you advice and give some documents for me?
Best Regards,
Join
i think you will have to use HSRP or VRRP for this solution.
Here you will get informations about HSRP: http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a91.shtml
And here is a 2nd link for a comparison between HSRP & VRRP (and GLBP ... but thats might not be that wat you would need) and on that site you would find some pdf's with a introduction for the configuration http://www.ciscoblog.com/archives/2006/04/hsrp_vs_vrrp_vs.html
