Load balancing over 2 ISPs based on subnets
amr2020eg
I am preparing configuration to support below requirements
Subnet1 172.29.3.0/25 use dialer1 internet link
Subnet2 172.29.3.128/25 user F0/1 internet link
Both subnets connect to HQ through s0/1/0network.JPG
This is the new configuration which i have created. i want to review it if it will work there or i need some changes
hostname Branch1
boot-start-marker
boot system flash:c2800nm-advipservicesk9-mz.124-22.T.bin
boot-end-marker
logging message-counter syslog
logging buffered 40960
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.29.3.1 172.29.3.10
ip dhcp excluded-address 172.29.4.1 172.29.4.10
ip dhcp excluded-address 172.29.3.129 172.29.3.139
ip dhcp pool Voice
network 172.29.4.0 255.255.255.224
default-router 172.29.4.1
option 150 ip 172.25.1.250
ip dhcp pool Data
network 172.29.3.0 255.255.255.128
default-router 172.29.3.1
dns-server 192.168.0.29 192.168.0.2 4.2.2.2 4.2.2.3
ip dhcp pool Data2
network 172.29.3.128 255.255.255.128
no ip domain lookup
no ipv6 cef
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.2
description <<DATA VLAN INTERFACE>>
encapsulation dot1Q 2
ip address 172.29.3.1 255.255.255.128
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0.3
description <<VOICE VLAN INTERFACE>>
Many Thanks,
Amr
encapsulation dot1Q 3
ip address 172.29.4.1 255.255.255.224
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.29.4.1
interface FastEthernet0/0.4
description <<DATA2 VLAN INTERFACE>>
encapsulation dot1Q 4
ip address 172.29.3.129 255.255.255.128
ip nat inside
interface FastEthernet0/1
description "ISP2"
ip address 192.168.1.2 255.255.255.252
ip nat outside
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.35 point-to-point
pvc 0 0/35
pppoe-client dial-pool-number 1
interface Serial0/1/0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type q933a
interface Serial0/1/0.16 point-to-point
description "VPN To HQ"
ip address 172.30.200.2 255.255.255.252
ip nat inside
snmp trap link-status
frame-relay interface-dlci 16
interface Dialer1
description "ISP1"
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication pap chap callin
ppp chap hostname ****
ppp chap password 7 *****
ppp pap sent-username **** password 7 *****
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 10.0.0.0 255.0.0.0 Serial0/1/0.16
ip route 172.0.0.0 255.0.0.0 Serial0/1/0.16
ip route 192.168.0.0 255.255.255.0 Serial0/1/0.16
no ip http server
no ip http secure-server
ip nat inside source route-map ISP1 interface Dialer1 overload
ip nat inside source route-map ISP2 interface fastethernet0/1 overload
access-list 101 permit ip 172.29.3.0 0.0.0.127 any
access-list 102 permit ip 172.29.3.129 0.0.0.127 any
route-map ISP1 permit 20
match ip address 101
match interface dialer1
route-map ISP2 permit 20
match ip address 102
match interface fastethernet0/1
control-plane
bridge 1 protocol ieee
bridge 1 route ip
mgcp fax t38 ecm
sccp local FastEthernet0/0.3
sccp ccm 172.25.1.250 identifier 1 priority 1 version 3.1
sccp
Richard Burts
There are several things in this config that puzzle me. But they are incidental to the main question of the original post, which is that one inside subnet should use one route to outside while the other subnet uses a different route to outside and that both would use the same route to the HQ. To achieve that requirement you need to implement Policy Based Routing. PBR is applied to the interface which receives the traffic from the source subnet. PBR uses a route map to select the traffic to which it will act and then sets the next hop for that traffic to use the particular outbound interface. So you will need a route map for each source subnet. Each route map will use a match statement referencing an access list. The ACL will deny the source of its own subnet and destination of HQ and in the next statement will permit the source of its subnet to any.
Rick
Rick
