Load balancing over two separate outside routers and two separate WAN Links
Thomas Reiling
Hi everybody,
I have one 2851 setup with two separate ISP links and have it configured for failover with BGP.  It works great but doesn't load balance.
Well now I have to new routers (3925's) to replace the single 2851 and I want to configure them to load balance over separate WAN links.
Can someone help figure out the best approach to make this happen?  I would really appreciate it.
Thank you,
Thomas Reiling
Mark Malone
i would use ebgp multi-path , have a look at this link
http://www.cisco.com/c/en/us/td/docs/ios/12_2sx/feature/guide/fsxeibmp.html
We're not using MPLS.  We have two separate Comcast Ethernet connections.
maximum-paths 2 can do the work for you.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The "best approach", IMO, would be to use PfR (if your routers support it).
