Load balancing WAN, inside and outside trafic
jmecklenburg
Level 2
Level 2
Hi NetPro
Which Cisco device do I need to make a load balancing and faiulre tolerance for two WAN links with different ISP both to inside and outside traffic considering allowed access to published services from WAN interface to LAN.
fixie rider
5 Replies 5
Giuseppe Larosa
Hello Javier,
using a powerful enough Cisco router with BGP multihoming is fine for outbound traffic.
However, you cannot control the inbound direction.
You can try to influence inbound paths by performing selective AS path prepending towards the ISP eBGP peers but you cannot expect a fair distribution.
This is a known limit of BGP4.
There are other options to optimize outbound traffic sharing including OER but again for inbound direction it is easier to implement a strict hierarchy on return traffic.
for BGP multihoming see
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
effective BGP multihoming would require your company to ask a BGP AS number to RIRs (ARIN, RIPE and the others) and to have associated to it one or more public address blocks
you can consider also a primary/secondary solution using NAT that provides only redundancy but with less requirements
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a0080091c8a.shtml
So depending on the size of your company the second option might be a better fit.
Hope to help
Giuseppe
Hi Guislar
If don't exist a load balancer like some Allot device?
fixie rider
Hello Javier,
again a load balancer could work for outbound but not for inbound traffic
Each subject in the internet is free to decide how it sends traffic but it cannot influence how the others send back the traffic to it.
This is a question of routing and of current technology.
Even if you don't use BGP it is used by your providers.
Hope to help
Giuseppe
thanks for your help
and for this implementation, a Cisco Router 3800 is enough?
fixie rider
Hello Javier,
a router C3845 can be enough if
you are not going to receive full routing table
the traffic volume the device needs to handle is within 50 Mbps (roughly)
Hope to help
Giuseppe
