load balancing
zaqtivi
on a 7513, how would you know if an nxt1 is being load balanced ? thanks.
cisand2002
Hello Zaqtivi,
I don't see a specific command to check load balancing on nxt1.
you can check utilization on different t1 (sh int sx/y/z) and compaire to see if all n serial has +/- same input/output utilization.
also from config you can see if doing load-sharing and from routing config.
HTH - please rate if answer you question
Cisand
thanks cisand ! what id like to know is from a 7513 router, what show command would be able to confirm if that ckt is being load balanced or not ...
I will give you an example to see if there is load balacing.
example:
access-list 100 permit ip host 10.1.1.1 any
debug ip packet 100
you 'll see at the output of debug that, there next peer to which router is sending packet is not the same.
Regards.
